Visitor efaz
Partial Reconfiguration: Measuring Zynq PCAP Reconfiguration Time
Hi everybody,
I started to analyze the performance of a software application which is able to partially reconfigure the Zynq Programmable Logic using the PCAP interface.
I basically added some lines of code to the function I'm using to load a partial bitstream from the DDR memory into the PL, "XDcfg_TransferBitfile", to measure how much time it takes to load a new partial bitstream. I'm copying the code below.
int XDcfg_TransferBitfile(XDcfg *DcfgInstPtr, int PartialCfg, u32 PartialAddress, u32 bitfile_length_words)
    u32 IntrStsReg = 0;
    float elapsed_time; //[us]
    int bitstream_dimension; //[kB]
    float avg_throughput; //[MB/s]
    XTime_GetTime(&tStart);
    XDcfg_Transfer(DcfgInstPtr, (u8 *)PartialAddress, bitfile_length_words,
        (u8 *)XDCFG_DMA_INVALID_ADDRESS,
        0, XDCFG_NON_SECURE_PCAP_WRITE);
    // Poll IXR_DMA_DONE
    IntrStsReg = XDcfg_IntrGetStatus(DcfgInstPtr);
    while ((IntrStsReg & XDCFG_IXR_DMA_DONE_MASK) !=
            XDCFG_IXR_DMA_DONE_MASK) {
    if (PartialCfg) {
        /* Poll IXR_D_P_DONE */
        while ((IntrStsReg & XDCFG_IXR_D_P_DONE_MASK) !=
                XDCFG_IXR_D_P_DONE_MASK) {
    } else {
        /* Poll IXR_PCFG_DONE */
        while ((IntrStsReg & XDCFG_IXR_PCFG_DONE_MASK) !=
                XDCFG_IXR_PCFG_DONE_MASK) {
        // Enable the level-shifters from PS to PL.
        Xil_Out32(SLCR_UNLOCK, SLCR_UNLOCK_VAL);
        Xil_Out32(SLCR_LVL_SHFTR_EN, 0xF);
        Xil_Out32(SLCR_LOCK, SLCR_LOCK_VAL);
    XTime_GetTime(&tEnd);
    elapsed_time = 1.0 * (tEnd - tStart) /(COUNTS_PER_SECOND/1000000);
    bitstream_dimension = bitfile_length_words*4/1000;
    avg_throughput = (bitstream_dimension / elapsed_time) * 1000.0;
    printf("Partial Reconfiguration took %.3fus\nBitstream dimension: %dKB\nAverage throughput: %fMB/s\n",
                               elapsed_time, bitstream_dimension, avg_throughput);
    return XST_SUCCESS;
The code above seems to work but I'm reading strange numbers:
-when I load for the first time a reconfigurable module the throughput is around 130MB/s, which is reasonable
-for the following reconfigurations of the reconfigurable module, however, the throughput goes up to almost 200GB/s
What am I doing wrong about the time measurements?
Thanks in advance
Visitor sdu_liuke
Re: Partial Reconfiguration: Measuring Zynq PCAP Reconfiguration Time
Hello,  efaz,  I met the same condition while trying  the example from Unversity Program(Lab3 reconfig_peripheral_lab):
  • Only the first time , the throughput is around 130MB/s, which is reasonable refer to UG585(145MB/s).
  • Other times, 109KB bitfile only costs about 5us, more than 190GB/s.
Why? May be caching ? or just programme the bit which is needed to be flip, which means ,in the LAB3,just 5us*130MB = 650*8 bit  are different?
Waiting for your answers, Thanks!
Have fun with FPGA
Visitor sdu_liuke
a small mistake : the throughput is 109KB / 5us = 20GB/s after first partial reconfiguration(109KB, 890us). Sorry
Have fun with FPGA
