Problem with PlanAHead, iMPACT and Ubuntu 14
I'm having problem to program ML605 using impact. I'm using Ubuntu 14.04LTS , and PlanAHead 14.7.
I'm able to synthesize the design and generate the bitstream, but when I launch the iMPACT, it cannot find the device ML605 connected via USB.
It gives those warnings.
WARNING:iMPACT - Module windrvr6 is not loaded. Please reinstall the cable drivers. See Answer Record 22648.
WARNING:iMPACT:923 - Can not find cable, check cable setup !
When I check using lsusb in the linux terminal the usb connection is there.
I'm stuck with this problem. Can someone help me?
Thank you
Andre
You have JTAG USB device with id 03fd:000d at the address 001:014
By checking my /etc/udev/rules.d/xusbdfwu.rules  (you can google this file)
I found that you need to program 'xusb_emb.hex' code into you JTAG.
My address for this file:
    /opt/Xilinx/14.5/LabTools/LabTools/data/xusb_emb.hex
or you can find it with find tool:
    cd /opt/Xilinx; find . -name  xusb_emb.hex
Then all you need is run fxload tool this way:
  sudo /sbin/fxload -v -t fx2 -I /opt/Xilinx/14.5/LabTools/LabTools/data/xusb_emb.hex -D /dev/bus/usb/001/014
(check path to .hex code file and path to usb device twice)
As result you should see in lsusb:
  Bus XXX Device YYY: ID 03fd:0008 Xilinx, Inc.     (then check rights for /dev/bus/usb/XXX/YYY or do sudo chmod a+rw)
And impact will work fine.
Usually udev does all this work.
Ubuntu is unsupported for PlanAhaed tool.
BTW did you check the AR http://www.xilinx.com/support/answers/22648.html
Thanks,Vijay
Hi Andre,
Cable drivers were not installed on the machine.
See this answer record for installing the cable drivers: http://www.xilinx.com/support/answers/54381.html
Vinay
Actually IMPACT and drivers support Ubuntu enough.
You dont need either windrv either parport, and no kernel drivers at all.
IMPACT can use libusb, so you need to install libusb, libusb-dev and fxload.
Also you need to install Digilent drivers (can be found with LabTools)
and pcusb (also present in LabTools) but better take from git://git.zerfleddert.de/usb-driver and run sudo ./setup_pcusb.
The only goal of setting up digilent and pcusb is prepare /etc/udev to program JTAG when it is found in the system.
(this scripts uses fxload - you can see it in text)
After udev sript did fxload programming than IMPACT can use USB jtag thrue libusb.
usb-driver/ from git also can emulate windrv using libusb, but you dont need this since IMACT 11.x as I remember
Cant find the install_script directory in <Xilinx install>/bin/[lin|lin64] or <Xilinx install>/bin/[lin|lin64].
I downloaded the installation files but it doesnt have the install script.
Could you tell me where can I find the install script, please ?
/opt/Xilinx/14.x/LabTools/common/bin/lin64/install_script/install_drivers/linux_drivers/pcusb
but better take pcusb from git, it contains significant fixes
if nothing helps put here your 'lsusb' output
I tried many things, but none of it worked.
http://lighttomorrow.wordpress.com/2011/12/18/how-to-install-digilent-cable-driver-for-xilinx-design-suite-on-ubuntu-11-10/
https://engineering.purdue.edu/elab/html/wiki-xilinx-tools-on-ubuntu.html
And now, my computer wont display because I did "apt-get update && apt-get upgrade".
I'm new to linux. I'm trying to solve this for a week, but I still cannot program ML605 through JTAG.
Attached is the lsusb output and output of iMPACT.
In the board I have set S2 to 001010 (6,5,4,3,2,1) and S1 (0000).
Please I need help.
Thank you,
Andre
mikerez.
I had this problem for a month.
Thank you.
Andre
generally its absolutely enough to get "usb-driver" from git://git.zerfleddert.de/usb-driver and run 'sudo setup_pcusb' with path to LabTools/LabTools
fresh fix for last Ubuntu
sudo ln -s /lib/x86_64-linux-gnu/libusb-0.1.so.4.4.4 /usr/lib/x86_64-linux-gnu/libusb.so
Could you please elaborate on this answer of yours? I have been getting windrvr6 errors for quite some time. I do not have Labtools installed but I have Impact installed. Can you provide a workaround for that?
Hi @vignesh_xilinx,
What is the OS are you using? If windows 7 refer this AR
http://www.xilinx.com/support/answers/44397.html
-Pratham
Hello
I using ubuntu 14.04. I noticed that the solution provided by mikerez suggests a woraround using windrvr6 driver. I dont have LabTools installed. I was wondering if the solution would work even without that ( i have impact installed though)
Thanks for your response
Vignesh
windrvr6 is not used
Impact directly uses libusb and USB device ID 03fd:0008 Xilinx, Inc. in Linux
Hi mikerez
Thanks. I was able to get past the windrvr6 error by following your solution. However, I have problems with subsequent steps in the design flow. I was able to download a bitstream with FSBL associated with it. In the subsequent steps of petalinux-boot --jtag --u-boot and petalinux-boot --jtag --kernel I am getting errors of unsupported version. Do you have any idea regarding how to resolve this issue?
Thanks in advance
Vignesh
Screenshot from 2015-05-07 12:07:41.png
Screenshot from 2015-05-07 12:08:51.png
