guilvard
Programming Flash Voltage ?
I am working on a design with a Spartan 6.
In order to program it, I will use a Xilinx XCF04S Flash.
If I anderstand correctly, the VCCO voltage of the Flash must be the same as the VCCO of the XC6 Bank containing the  Programming signals (INITb, DONE, BUSY, etc..)
On the XC6 they are in BANK2.
As, in my design, the Bank2 VCCO is 2.5V in order to use LVDS25 IO's, the  FLASH VCCO must also be 2.5V.
I am right?
I assume the VCCj Flash voltage allows to define the TDI, TMS, TCK, TDO voltage....
But, I did not manage to find what was the voltage of these signals on the Spartan 6...
Therefore, what is the suppply voltage for VCCj?
Thank you for your help,
Alex
guilvard
I found the answer !
Everything is specified on the UG380.pdf page 24/25
Alex
guilvard
Alex
