Visitor fictive
Programming Fpga via Linux - Zedboard
Hello, I don't know if I'm in the right forum. Please move my message if I'm wrong.
Hello everyone!
I'm in a middle of a project, I will describe it to you:
In vivdo I have used the board of Zedboard, and I used the ip core of the Zynq 7000.
I have also add an axi fifo (but it could be any other peripheral) I have connected the fido to the Zynq up core.
Now I know I can expor my design and to program the fifo via the ask of vivdo.
But I want to program it on the operating system I have on the zedboard - Linux.
For example, in the c code I wirte data to the fifo..
How do I do it?
I have already read this guide:
http://www.fpgadeveloper.com/2014/08/creating-a-custom-ip-block-in-vivad...
But here he just check his ipcore with the sdk. I want to program(to talk ) with the peripherals via the code on the Linux. (Sorry about my English i hope you understand what do I need..)
So if you have a guide or you can explain me it will be wonderful!
Thank you!
Idan.
Teacher muzaffer
Re: Programming Fpga via Linux - Zedboard
The AXI IP you generate is connected to one of the ports on the PS/PL interface and it has an address. In Linux you mmap this address and get a usable pointer. At this point you can do read/write transactions to your IP's registers mapped to AXI bus.
