Read a (maybe unlock) chip ?
Hello all,
I want to dump a xilinx chip to make a copy of a board because I can't buy it, the seller closed so I needto do this.
It's a daughter board for a nissan skyline GTR R34 ECU, this board is from technosquare
However if I try to read the chip and if it's lock, will it be corrupted ? (like some protections for CD/DVD game) or Will I just have an ecrypted dump file ? The chip is a XC95144
Thanks for all.
Professor
Professor
Re: Read a (maybe unlock) chip ?
Reading the chip will not hurt it.  As I recall, these older parts have no encryption, but they might
have a "security fuse" which essentially prevents readback.  If the security feature is set, then
wht you read back will be something like all 1's.  In any case it's useless.  So you can't copy
the chip if the security is set.
-- Gabor
-- Gabor
Professor
Professor
-- Gabor
-- Gabor
Historian
Historian
Most of us are not in the business of helping people clone IP. Sorry.
Professor
Professor
I forgot to add that another "feature" of a security fuse is that even if the part is re-programmable,
you must erase the entire part in order to reset the security fuse.  Thus if you try to "unlock"
the chip you will erase it and cannot copy it.
-- Gabor
-- Gabor
Thanks for your reply guys,
I just wanted to be sure (I work on some microchip chip) so I hope the chip have not this fuse...
I must clone it because this board it's not in selling anymore that's why I must do that.
Historian
Historian
You MUST clone it? Regardless of its production status, the company that made the part owns the design and as such you are not entitled to clone it unless they've given you a license to do so.
Having said that, when you fire it up the first time, please video it so we can see your car blow up!
