Participant sticken
Reading data form GPIO
Hello everybody,
How can I read data from GPIO of an FPGA? Is there any special/dedicated instruction or have I to declare the entity of a component (using VHDL) and connect the GPIO port to the "in" port of my component?
Any help/link/hint would be much appreciated.
Thank you,
sticken
Re: Reading data form GPIO
You are designing hardware circuits for an FPGA and not writing code for a CPU.  So the concept of reading a GPIO does not exist.  The FPGA does have bidirectional IO pins and these can be directly connected to the hardware circuits that you are designing.
Participant sticken
You're right! I have some knowledge of VHDL and hardware circuits, but I've never worked with an FPGA. How can I connect IO pins to I/O ports of my circuit?
Thanks in advance.
sticken
The synthesizer will automatically insert IO buffers on the to level ports.
Historian
Historian
Thanks in advance.
Is your "circuit" the external stuff connected to the FPGA, or is it the logic you're describing that lives IN the FPGA?
Participant sticken
bassman59, my circuit is the logic that lives in the FPGA. So the synthesizer will insert the I/O buffers but how can I send data from outside to the circuit inside the FPGA?
Thanks in advance,
Matteo
You can send data from outside world to inside FPGA through GPIO's.
library ieee;
use ieee.std_logic_1164.all;
entity test_in is
   port (
               clk         : in std_logic;
               rst         : in std_logic;
               gpio_i     : in std_logic;
               gpio_o     : out std_logic
end test_in;
Architecture rtl of test_in is
signal temp : std_logic;
begin
process(clk,rst)
  begin
     if(rst='1') then
        temp <= '0';
     elsif(Rising_edge(clk)) then
       temp <= gpio_i;
      end if;
 end process;
  gpio_o <= temp;
    end rtl;
This is just a simple code illustrating how to take data from outside,inside the FPGA through GPIO pin an gving output on other GPIO pin or GPIO LED.
However if you want to read the data from GPIO you may use Logic Analyser to check whether there is some signal i.e data present on GPIO or not...
By applying the data to the pin of the the FPGA that you have assigned the input to.  You seem to be missing some very basic hardware and FPGA concepts.  I would strongly encourage you to go through some of the simple ISE tutorials.
Historian
Historian
That's overly complicating the matter.
"GPIO" is a microcontroller concept which is irrelevant in the FPGA world. All FPGA pins are GPIO in a sense. They ARE general purpose and they ARE I/O.
Participant sticken
Could you tell me how/where to find those tutorials?
Thank you
Historian
Historian
Thank you
a) Turn on your computer.
b) Log in.
c) Launch your favorite Web browser.
d) enter www.google.com into the address bar.
e) Enter Xilinx ISE tutorial into the search bar.
f) Press enter.
g) ???
h) Profit!
