Rule violation gpio have no routable drivers!
What I did was to add some set_property LOC constraints, then these errors happen during generating bitstream, and stopped with error
In Vivado Messeges:
 58 net(s) have no routable drivers. The problem bus(es) and/or net(s) are
*/gpio_pin/OUT
*/gpio_pin/OUT
*/gpio_pin/OUT
*/gpio_pin/OUT
*/gpio_pin/OUT (the first 15 of 58 listed).
Hi @bowen_fu
Open Implemented design and check what are the drivers and loads of these nets.
Deepika.
Community Manager
Community Manager
Are you targeting Zynq? If yes, please make sure that you enabled GPIO EMIO if the defined LOC constraints are on PL side. By default, GPIO MIO is choosen.
It turns out to be tool bugs!!!
Vivado stops with error when generating bitstream.
We rerun the Generate Bitstream, then it passes.
What is that......
Does synopsys synplify perform better?
@bowen_fu Can you post  more details like Viavdo version, Part you are using and the log files runme.log & *.vdi files.
This will help to look into the issue.
Also, can you check what happens if you open routed.dcp file & run command: write_bitstream the first time
- Giri
Community Manager
Community Manager
This looks odd. If the errors during generate bitstream are genuine, we should hit the error every time.
Can you please compare the generate bitstream log in both cases (working & not-working) to find the differences?
