meganadhan
State Machine design
Dear All,
we need to design a state machine having the following behavior
MOD 1 :       IDLE -> st1 -> st2 -> st3 -> st4 -> st1 -> st2 -> st3 -> st4 ->st1 -> st2 - - -   and so on.
MOD 2:        IDLE -> st1 -> st2 -> st3 -> st4 -> st5 -> st1 -> st2 -> st3 ->st4 -> st5 -> st1-> st2 -> st3 --- so on
MOD 3 :       IDLE -> st1 -> st2 -> st5 -> st3 -> st4 -> st5 -> st1 -> st2 ->st5 -> st3 -> st4 -> st5 ---- so on
MOD 4 :       IDLE -> st1 -> st5 -> st2 -> st5 -> st3 -> st5 -> st4 ->st5 -> st1 -> st5 -> st2 -> st5 -> st3 -> st5 so on
change from each state depend on a ready signal from a slave(may need to remain in a state until the slave is ready)
1. How we can implement this state machine logic with minimum logic (avoid large comparators in each state ) ?
Any answers would be greatly appreciated .
Meganadan
aher
hi,
can you please explain what is mod1, mod2, mod3, mod4?
are you switching between these states depending on some variable?
thanks,
Shreyas
Try to search answer for your issue in forums or xilinx user guides before you post a new thread.
Kindly note- Please mark the Answer as "Accept as solution" if information provided solves your query.
Give Kudos (star provided in left) to a post which you think is helpful and reply oriented.
Give Kudos (star provided in right) to a post which you think is helpful and reply oriented.
meganadhan
1. MOD1 and MOD2 are 2 bit inputs to the state machine which need to be checked at IDLE state(frame start) state only
2. State swiching is controlled only by the ready signal from the slave.
3. Once mod is set for a frame it should follow the pattern as shown.
Meganadhan
vijayak
Some coding examples are given @ http://www.asic-world.com/tidbits/verilog_fsm.html
Thanks,Vijay
anusheel
Refer below link for FPGA based FSM coding example:
http://www.xilinx.com/support/documentation/university/ISE-Teaching/HDL-Design/14x/Nexys3/Verilog/docs-pdf/lab10.pdf
-fsm_extraction is also available in Vivado.
Anusheel
Helpful answer -> Give Kudos
muzaffer
make three lookup tables with the sequences you quote, ie for mod 3 {1, 2, 5, 3, 4, 5, -1} where -1 indicates return to index 0 and others indicate next state. have 4 state after idle, one for each mod and have each modx state loop over the ready signal and pick from the respective table. You need to make sure your state machine coding stays current with the contents of the lookup table.
meganadhan
Hi Muzafir,
thanks for your prompt reply.
Could u pls elaborate ?
Megandhan
