Uart 4M Baud Rate
I need 4M Baud Uart. I send one character(e.g. 0x19) to Logic analyzer. After 1M baud(e.g. 2M,4M),i get invalid character.
For example;
1M baud : 0x19(valid)
2M baud : 0x39(invalid)
4M baud : 0x8E(invalid)
I use standart uart code and derive clock from 125MHz on board osc(zybo board). I use clock IP to convert it to 100MHz. And I divide 25 to get 4MHz(4M baud).
I try all possibilities using slewrate/drive power/cmos-lvttl etc. Unfortunately, i can't read correct data(0x19) at 4M baud rate.
Bit pattern(00011001) very similar, i think there is a timing(rise-fall times) problem, logic analyzer decode wrong.
1M baud
4M baud
Is it possible to reach 4M baud rates with uart?
Any help would be apprecated.
Re: Uart 4M Baud Rate
The problem solved:
Logic analyzer capture values(threshold&hysteresis)before was very low. I tune these values. It decode character correctly now.
hi,
the uart IP in the IP catalog can reach upto a maximum of 921,600
refer to page 15 of this PG. https://www.xilinx.com/support/documentation/ip_documentation/axi_uartlite/v2_0/pg142-axi-uartlite.pdf
--hs
I use custom VHDL coded UART. You can see in figure.
The problem solved:
Visitor andrea1984
I've the same problem using AXI UART. I saw that you wrote the UART driver. Can you give me the code? I need a 6Mbaud, and I don't know how to do.
