Observer daldoul
VHDL " range=>'0' "
Hello all! I'm new to VHDL and i need some help to understand a statement
whitch uses range => '0' ; that's a part of the code
architecture Behavioral of hb_fir is
type tab_reg is array (K downto 0) of signed(15 downto 0)
signal reg2 :tab_reg;
reg2(1) <= (reg2(1)'range => '0'); whats this do?
end Behavioral;
Mentor hgleamon1
Mentor
Re: VHDL " range=>'0' "
I think the "range" descriptor refers to the size of the vector in number of bits. That is, the "range" of reg2 is 16 bits. This statement has the effect of assigning all bits in that vector (in this case, reg2(1)) to 0.
It is similar, I believe, to writing
reg2(1) <= (others => '0');
Hope this is true and therefore helps!
Howard
"That which we must learn to do, we learn by doing." - Aristotle
Historian
Historian
end Behavioral;
If you have a signal declared like the following:
    signal foo : std_logic_vector(7 downto 0);
and you use the 'range attribute with it, like foo'range, the 'range has the value (7 downto 0).
A signal like this:
    signal bar: std_logic_vector(0 to 3);
has a 'range attribute foo'range as (0 to 3).
So say, for instance, you have a big vector and you want to assign a smaller vector to that bigger vector:
    signal bletch : std_logic_vector(31 downto 0);
you could do
    bletch(foo'range) <= foo;
if you want to assign the value of foo to the lower byte of bletch.
You can also loop over a range:
    thisloop : for bc in foo'range loop
        foo(bc) <= something;
    end loop thisloop;
Attributes are useful conveniences. Use them!
