smnsext
Vivado USR_ACCESSE2
Please move this thread if it fits somewhere else.
I'm working with Vivado for the VC707 board and now I need the USR_ACCESSE2 register (A JTAG register to get a hardware cofiguration revision number). I found this thread and this one. In the user guide ug953 and xapp497 there are only commands for ISE and related tools. And a static information is completly fine for me, i don't need that data-interface via VHDL. So here are my questions:
  • How do I translate the old command "bitgen -g USR_ACCESS TIMESTAMP" to the new tools (generate bitstream step)?
  • If this command is not implemented (yet) how do I set my constrains inside my .xdc correct for my board or works the instantiation ot of the box?
  • How do I save information with the instantiation?
I hope I missed something and you can help me. TIA!
josephsamson
This is what I have in my .xdc file:
set_property BITSTREAM.CONFIG.USR_ACCESS TIMESTAMP [current_design]
I don't have any special bitstream project settings.
Joe
josephsamson
Joe
pratham
@smnsext Command given by @josephsamson is all you want.
-Pratham
smnsext
Nice, it worked. NOW I know the correct search term, but i did'nt find a solution with "USR_ACCESSE2".
Now I'm working on a script to get the actual SVN revision and I'm fine, thank you!
prashant.nilkund
The document XAPP1232 under this link : https://www.xilinx.com/support/documentation/application_notes/xapp1232-bitstream-id-with-usr_access.pdf
explains how to quite elaborately.
