What's the necessity to use ibuf component ?
I am creating a project on a Virtex II pro. I have a question concerning the use of IBUF component. In my project I don't use it, however my project works properly. My question is, is it necessary to instantiate IBUF and OBUF to avoid problem in the future ? what's the necessity of that ?
Thanks by advance
Instructor
Instructor
Re: What's the necessity to use ibuf component ?
In most cases you don't need to instantiate IBUF components.  I've found that the only
reasons I need to instantiate them is either because XST tries to insert more than one IBUF
on a single input (usually a DCM-related issue) or because XST doesn't infer differential
input buffers, so you need to instantiate IBUFDS components.  By the way, Lattice tools
don't require you to instantiate differential buffers.  Differential I/O's are treated like single-ended
using only the positive side of the pair.  Defining the IO standard as something differential
forces their tools to infer the differential buffer and assign the negative side of the pair.  In
both the case of Lattice and Xilinx, the parts have only one choice to place the positive vs. negative
part of a differential pair, so there's no reason Xilinx couldn't do something similar.
-- Gabor
-- Gabor
Your synthesizer is adding the IBUFs and OBUFs automatically to your design.
Scholar drjohnsmith
I work on premise I;m a control freak,
  so instnatiate what I want,
Historian
Historian
@drjohnsmith wrote:
Why make things so difficult?
Scholar drjohnsmith
one word answer,
   predictability.
just my way of doing things,
Instructor
Instructor
-- Gabor
-- Gabor
Thank you very much for this explanation !
