binary multiplication in vhdl
hi,
I am having problem with simulink, when simulationg a test bench concerning binary multiplication in vhdl.
the code for the code is this one:
library IEEE;
use IEEE.std_logic_1164.all;
use IEEE.std_logic_arith.all;
entity vmul8x8i is
port (
X: in UNSIGNED (7 downto 0);
Y: in UNSIGNED (7 downto 0);
P: out UNSIGNED (15 downto 0)
end vmul8x8i;
architecture vmul8x8i_arch of vmul8x8i is
begin
P <= X * Y;
end vmul8x8i_arch;
and for the test bench is:
-- VHDL Test Bench Created from source file vmul8x8i.vhd -- 22:46:03 12/04/2007
-- Notes:
-- This testbench has been automatically generated using types std_logic and
-- std_logic_vector for the ports of the unit under test.  Xilinx recommends
-- that these types always be used for the top-level I/O of a design in order
-- to guarantee that the testbench will bind correctly to the post-implementation
-- simulation model.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
USE ieee.numeric_std.ALL;
ENTITY vmul8x8i_mul_t_vhd_tb IS
END vmul8x8i_mul_t_vhd_tb;
ARCHITECTURE behavior OF vmul8x8i_mul_t_vhd_tb IS
 COMPONENT vmul8x8i
 PORT(
  X : IN std_logic_vector(7 downto 0);
  Y : IN std_logic_vector(7 downto 0);
  P : OUT std_logic_vector(15 downto 0)
 END COMPONENT;
 SIGNAL X :  std_logic_vector(7 downto 0);
 SIGNAL Y :  std_logic_vector(7 downto 0);
 SIGNAL P :  std_logic_vector(15 downto 0);
BEGIN
 uut: vmul8x8i PORT MAP(
  X => X,
  Y => Y,
  P => P
-- *** Test Bench - User Defined Section ***
   tb : PROCESS
   BEGIN
   X <= "00000001";
   Y <= "00000010";
      wait; -- will wait forever
   END PROCESS;
-- *** End Test Bench - User Defined Section ***
END;
and the error reported is:
types do not match for port X.
can anybody tell me  the reason of this.
thanks,
Hello....
The problem is that the entity declaration of the vmul8x8i component uses the UNSIGNED type for the ports while the testbench uses std_logic_vector type (this is also noted at the auto-generated testbench) and also that you use the std_logic_arith package.
The best way is to use everywhere std_logic_vector type and the std_logic_unsigned package. This package contains functions that allow operations with STD_LOGIC_VECTOR data to be performed as if the data were of type UNSIGNED. This is also a simple way of allowing data of type STD_LOGIC_VECTOR to participate directly in arithmetic operations.
Alternatively you can use everywhere the unsigned type.
Hope that helps....
George
Hi George,
Thanks a lot for the answer. I adopted your solution and now the simulations runs as expected.
Ivan
Despite the naming, std_logic_arith and std_logic_unsigned aren't actually standard packages.  While I won't argue with a working solution, if you ever need to combine the use of signed and unsigned arithmetic in a system, they can lead to problems, so for larger systems I'd recommend sticking to IEEE.numeric_std.  Using numeric_std does mean that you'll sometimes need to code explicit type casts between std_logic_vector, unsigned, and signed types, but IMHO that's a fairly small price to pay.
Hi, I need structure model code for 8-bit muliplier using conventional method. Can anyone help me out of this?
