jamesjisun
can I specify which interconnection to use during synthesis?
Hi there,
I am wondering if I can ask the synthesis tools to use interconnection I prefer? such as if there is long wire available, please use long wire instead of doublewire or other kind of wire.
J
eteam00
Professor
Professor
Not as far as I know.  Why would you want to do such a thing?
-- Bob Elkind
SIGNATURE:
Summary:
jamesjisun
Hi Bob,
Thanks for the reply. I want to use long wires to compare the performance of my design with short wires.
Cheers,
J
joelby
Advisor
Advisor
I doubt there's much call for a parameter to do this, but you can fiddle with the routing of your design using FPGA Editor, and to make the changes a bit more permanent, add user constraints for the routing.
jamesjisun
Yeah, I am trying to do this.  However, it's too complicated in FPGA editor. I can point out which long line I want to use, but it's hard to get it routed to a specific SLICE. Is there a way that I can select long line and let it autoroute for the rest of the path instead of the whole path being rerouted?
joelby
Advisor
Advisor
You could do something crazy, like wire two pins on the far side of the FPGA together and use them as an input and output.
That should give you a large routing and pad delay, which is even adjustable if you have a big spool of wire.
jamesjisun
actually, in that case, FPGA editor's autoroute will utilize short wires to be segmented instead of a long wire placed...
joelby
Advisor
Advisor
Sorry, I think I was taking the definition of 'long wires' a bit too literally.
