Newbie levi111
converting .MCS to .hex or .bin
Hi there,
I have a xilinx .msc which contains bitfile data + micorblaze C code.
Looking at the .mcs I can see that there's around 1meg of empty space between the microblaze code and the bitfile data.
I can tell that by looking at the .mcs address vectors which are located before each data segment.
However, when using promgen to convert the .msc to .bin, the result is one file where the C code starts immediately after the bitfile data. This looks like a bug in the promgen conversion, or, something I don't do right:
promgen -w -p bin -r file1.mcs -o file1.bin
Happy to hear if anyone has any idea
Amir
Instructor
Instructor
Re: converting .MCS to .hex or .bin
It sounds like a bug, and I can easily see how it happens.  a .bin or .hex file has no addressing info in it, so the only way to deal with the gap in the MCS file would be to pad the data with some value (fill in the approximately 1M between the end of the bit file and the start of the code using 0 or some other value).  It would seem that the file converter is ignoring the gap in the .mcs addressing and just packing the two sections together.
What's the reason you're doing this file conversion?  i.e. what do you need a .bin or .hex file for?
-- Gabor
Please check http://www.xilinx.com/support/answers/36210.html
Community Manager
Community Manager
The command is correct.  Which version of tools are you using?
