geco.kevin
csv file based LUT
Hello all,
I am doing a project that requires me to implement a fairly large LUT in verilog. I'd like to generate the values in MATLAB and then import them into the verilog with a .csv or similar file, rather than just typing them all in by hand. Does anyone have any advice as to how to do this?
drjohnsmith
Thank you
interesting,
Do I understand then by LUT your meaning the RAM blocks,
    and your using them as a Look Up Table to do the distortion ,
You can use an external file to load RAMs directly
    this might give you a few pointers,
https://forums.xilinx.com/t5/Spartan-Family-FPGAs/Initializing-Block-RAM-with-External-Data-File/td-p/229193
Loading RAMS externally is  used a lot in the PicoBlaze project, allows one to change the code in the ram without having to re compile the FPGA completely,
Have fun and let us know how it goes,
evgenis1
Advisor
Advisor
One way to implement this is as follows. Instead of generating CSV with the LUT values, you can generate Verilog file. Something like that:
initial begin: my_lut_vals
lut_val[0] = 'h11223344
lut_val[1] = 'h55667788
end
Then include that file in place you instantiate the LUT.
reg [31:0] lut_vals [1:N];
`include "my_lut_vals.vh"
Evgeni
drjohnsmith
Can I ask , for my own knowledge why you want to implement the logic values in MATLAB ?
geco.kevin
I am making a driver, and I want to implement complex digital predistortion to the data. I can use Matlab to generate filters and such and then load the results into a LUT. This takes the burden off of circuitry doing computationally intensive work.
drjohnsmith
Thank you
interesting,
