prem_dreams4u
hardware co-simulation for ML505 or XUPV5-LX110T
hi..!
i need your help, my target board is ML505 xc5vlx110t-1ff1136(i dont know if it is also called as ML509 or
XUPV5-LX110T)
screen shot 1
in above figure iam able to generate HDL netlist for my target device virtex5 xc5vlx110t-1ff1136
but i wanna do hardware co-simulation, so in system generator token i took option "Hardware co-simulation" as shown below, but my target board ML505 is not in the list, so i chose "New Compilation Target".
screen shot 2
and how to fill those options?
in "System Generator Board Description Builder"
i think for hardware co-simulation any board with jtag can be used...
also installation of new board
in "System Generator Board Description Builder" (for example ML505) is very easy if xilinx support provides .xml files for that particular board
so that by clicking button "Load" in "System Generator Board Description Builder" we can input .xml file you give and install support for new board.
because
adding ports or pins that are about 1000, is a headache, so xilinx must have a solution....!!!!!
if images above are not clear u can plz go here and zoom
http://picasaweb.google.co.in/prem.gprec/Project
Message Edited by prem_dreams4u on 09-27-2009 01:19 PM
ywu
When creating your own HWCOSIM target, you don't have to specify every single IOs available on the FPAG. You only need to add the ports that you used in your model. This blog http://myfpgablog.blogspot.com/2009/12/sysgen-create-new-hwcosim-target-with.html has step-by-step instructions on how to fill in the information for the SBDBuilder.
Cheers,
Jim
sofiene
Hello prem_dreams4u
I have the same board, and I have a problem with,
You can see my post here
Please tell me about the easier Board/PC way of connection (JTAG or Ethernet) for a successful HW co-sim.
How can you did it ?
Thank you in advance
Sofiene
