help in "if" condition in verilog having arguments 24 bit wide
Following are the relevant lines of code
 reg [5:0] demux_state = 6'b000000; // MJ Reduced from 7 to 6 bits
   reg [23:0] demux_timeout = 23'd0; // MJ Timeout if idle & reset state
 always @(posedge clk)
demux_timeout <= demux_timeout + 24'd1;
// Timeout after 8 million clock at 100Mhz is 80ms, which should be
// OK for all sensible clock speeds eg 20MHz is 400ms, 200MHz is 40ms
// TODO ought to parameterise, but this should be fine (4800 baud is
// one byte every 2ms approx)
if (demux_timeout & 24'h800000)
begin
demux_state <= 0;
demux_timeout <= 0;
end"
The complete code can be found at
I am unable to understand what the condition "if (demux_timeout & 24'h800000)" evaluates? I read that if condition can have either a value of 1 (true) or 0(false). But in the above example the arguments of the AND operation: "demux_timeout" and "24'h800000" are 24 bit wide so performing bitwise-AND ('&') will result in a 24 bit output so how does the if condition sets to 1 bit 1 or 0?
Please help.
Thanks and regards.
The expression passed to if is converted boolean by a non-zero check ie (exp != 0). This has a value of 1 if all bits of the expression are zero and a value of zero if any of the bits are set. It is also similar to a 'reduction or'
"The expression passed to if is converted boolean by a non-zero check ie (exp != 0). This has a value of 1 if all bits of the expression are zero and a value of zero if any of the bits are set. It is also similar to a 'reduction or'" .
I checked in simulation that if demux_timeout is 24'h800000 in a clock pulse then demux_timeout <= 0; is executed the next clock pulse and then onwards demux_timeout gets incremented by 1 until it again becomes 24'h800000 and the process repeats. So demux_timeout behaves as a counter whose last value is 24'h800000 after which it again goes to 0 and repeats counting incrementing by 1 each clock pulse.So the if condition is getting a value of 1 when demux_timeout is 24'h800000 that is the result of the '&' operation in the if condition is 24'h800000 so MSB is set when if is getting a 1 unlike you said that all bits need to be zero for the if expression to get a value of 1
Yeah, the polarity in my answer is inverted. The value is zero if all the bits of the expression are zero and 1 if any of the bits are set. The latter description is correct in the sense that this is the behavior of a 'reduction-or'.
