Observer alexmiculescu
parallel vs sequencial
Hi! I don't understand how non blocking assignments are executed in sequence or in parallel?
always @(posedge clk)
begin
x = 2;
y = x;
end
vs
fork
x = 2;
y = x;
join
vs
assign x = 2;
assign y
= x;
I don't grasp what is happening at the hardware level. In what cases race condition might occur? If all those are executed in sequence what are the advantages? Thank you!
Teacher muzaffer
Re: parallel vs sequencial
@alexmiculescu minor comment: nonblocking assignments are designated with '<=' also they're only valid in procedural assignments, not continuous.
don't forget that verilog is simulated based on event queues. In a nonblocking assignment, both right hand-sides of the assignment are calculated and put into a queue. When time progresses and the assignments become pending, they are assigned to the left-hand side in the same event step. This allows the parallel execution of nonblocking assignments.
Scholar u4223374
In hardware it's all parallel. However, the synthesis tool is able to make the parallel hardware act like it's doing sequential execution - so blocking assignments "look" sequential even though they aren't.
Race conditions should not occur. As far as I know, it's not possible to cause a race condition that can actually be synthesized; race conditions tend to result in multiple-driver errors during synthesis. You can get race conditions in hardware (eg. a signal that doesn't quite reach the flip-flop before the relevant clock edge) but those shouldn't occur if the design is correctly constrained and it passes timing. In short, if you're seeing race conditions, the tools will probably be throwing either errors or warnings.
