selecting a bufgmux
This is a conceptual question so don't worry that there's no code attached.
I was wondering, is it possible to add a constraint in the ucf file that will tell the map and/or place and route tool which bufgmux to use for a given clock input? For the record I am using verilog with ISE 14.7.
Kevin
Re: selecting a bufgmux
You  can specify the location constraint using the LOC
Check below links.
http://forums.xilinx.com/t5/Implementation/ISE-13-2-BUFGMUX-wrongly-placed/td-p/192168
http://forums.xilinx.com/t5/Spartan-Family-FPGAs/BUFGMUX-location-constraint-on-Spartan3A/td-p/352219
Satish
Check below links.
Satish
