zubin_kumar31
setting and resetting the XIL_TIMING_ALLOW_IMPOSSIBLE
hi,
i have xilinx ISE 10.1 on windows XP.
i had some timing issues in map so I set the xil_timing_allow_impossible to 1 in the tcl window in ISE.
the map went through.
however, now when I reset the xil_timing_allow_impossible back to 0, map is still completing successfully, even though I can see some timing violations in the post map timing report.
the syntax I used to set the  env variable is -
% set env(XIL_TIMING_ALLOW_IMPOSSIBLE) 1
1
% echo $env(XIL_TIMING_ALLOW_IMPOSSIBLE)
1
the syntax I used to reset the env variable is -
% set env(XIL_TIMING_ALLOW_IMPOSSIBLE) 0
0
0
So am I even setting/resetting this env. variable properly? or am I missing something in the syntax?
And if I am resetting the variable properly, how come map goes through next time around, even when there are timing violations.
Help!
z.
achutha
Once after modifying the variable have you closed the ISE and relaunch ?
Please try to re-launch the tool and the variable is modified.
Achutha
zubin_kumar31
i did relaunch ISE, however, after launching it again, when i do -
i get the error message -
can't read "env(XIL_TIMING_ALLOW_IMPOSSIBLE)": no such variable
do i need to reset this env variable after relaunching and then echo it?
i would assume since its a xilinx env variable, it should show the prev. value that was set ...
muzaffer
I think the tools are checking whether the environment variable is defined at all and not the value of it. So removing the variable is the right thing to do instead of setting it to zero. Did you try running through the flow again after removing it?
zubin_kumar31
ive done the following (in sequence) -
-set the xil_timing_allow_impossible to 0
-shut down all the ISE instances i might have open
-shut down the computer
-restart the computer, open the project again
-cleanup project
-run the map again ... BUT map is still succeeding, even though in the post map timing report, there are failures and errors!
echo of xil_timing_allow_impossible again says - variable not present.
how else can i reset this variable????????????????
please help!! :( :(
