aapatel374
vhdl code
hi, i want a vhdl code for following logic.
i have 20 signed numbers,like.
-2 -2 0 0 0 0 -2 -2 0 0 0 0 2 2 0 0 0 0 2 2
1) i want to put them in group of 4 numbers like,
-2-200 00-2-2 0000 2200 0022
2)i want sum of that all each group internally like
-2+-2+0+0 = -4
0+0+-2+-2= -4
0+0+0+0=0
2+2+0+0=4
0+0+2+2=4
3) i want put this answers in seperate memory
like,
-4 -4 0 4 4
last i want this signed vector in memory.
can anyone help me?
thank u.
regards,
AAP
drjohnsmith
So
what algorithum / structure are you thinking off ?
Where are you starting from ?
eilert
Hi AAP,
what Interface do you use to get the numbers?
Do they come in parallel or sequential or do you have to read them from a RAM?
What signal type are you going to use?
Since you are going to write the results to a memory you need a FSM anyway.
Is there a difference between your mentioned "seperate memory" and the "last wanted memory"?
have a nice synthesis
  eilert
aapatel374
hi ,
thanku for response.
i have to read results from memory.seperate memory means another memory.
aapatel374
 hi thank u for response.
 i have to implement multiuser cdma on spartan ii kit. this is a last part.
eilert
when you have two memories (one for input and one for output) then it is quite simple:
You need two counters for the input and output adresses, an adder connected to an accumulating register, and a small FSMs that triggers the reads and writes and resets the accumulating register for each calculation.
 You can speed up things a little by using more than one adder/accumulator but still you have to read all the data sequentially and so the gain may be quite small.
Have a nice synthesis
  Eilert
aapatel374
HI THANK U FOR YOUR RESPONSE BUT
I DIDN`T GET ANYTHING SORRY...
eilert
In that case you should join a class for digital electronics first.
(or read a good book like >Bebop to the Boolean Boogie<)
FSMs, accumulating registers, adders and counters etc. are basic building blocks for digital designs,
and without that knowledge you are simply lost.
  Eilert
