Accelerate sobel Ip core function in PYNQ z1 board
https://github.com/ATaylorCEngFIET/Hackster-using this code i have sobel filter IP block.but ididnot get integrated vivado blockdesign using pynq z1 board.i need to create overlay for sobel filter..please share your suggestions
回复: Accelerate sobel Ip core function in PYNQ z1 board
Hi xilin@x ,
    Creating a custom overlay on PYNQ requires a relatively solid Vivado IPI design capabilities. It is recommended that you can flow the UG871 chapter9&10 to get familiar with the design flow.
   PS:The github link is invalid.
Wen
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
Hi xilin@x
Do you have any update on this?
If you issue is resolved would you mind sharing your solution with the community?
Aoife
i accelrate sobel filter function but i got output baground image is blue color instead of black..i dont know how to resolve this
Hi xilin@x
Did you go through the tutorials suggested by @wenchen ?
Could you provide a new github link?
Aoife
