Visitor w514986395
An IP encapsulated problem
Recently,I made an IP of 2D-FFT algorithm about  the image processing, and the tool used is HLS. I can completed simulation and implementation. But when encapsulated into IP, the following error occurred.
I was puzzled for a long time. How can I solve this problem?
Re: An IP encapsulated problem
Hello @w514986395,
Can you please describe a bit more about where in the flow this error occurs? For example, in HLS, you mention it passed simulation. Did it also pass CoSimulation? When running the export process from HLS, were you able to check the synthesize and implementation boxes and have it pass that without error as well?
Or, is this error in the IP integrator when using the IP, or with an RTL instantiation of the IP?
OK, thank you for any additional information you can provide.
Scott
