11-18-2020 03:38 AM
Hi everybody,
I running the cosimulation for the example design of Xilinx repo:
https://github.com/Xilinx/HLS-Tiny-Tutorials
The example is: interface_axi_master
I made a small modification to that example following the code:
void example(volatile int *a){ #pragma HLS INTERFACE m_axi port=a depth=50 int i; int buff[50]; //memcpy creates a burst access to memory //multiple calls of memcpy cannot be pipelined and will be scheduled sequentially //memcpy requires a local buffer to store the results of the memory transaction for(i=0; i < 50; i++){ buff[i] = buff[i] + 100; } memcpy((int *)a,buff,50*sizeof(int)); memcpy(buff,(const int*)a,50*sizeof(int)); }
I the original example the instructions flow is a:
READ (memcpy)
MODIFICATION (for cycle)
WRITE(memcpy)
My modification,as listed in the code posted above, consists on:
WRITE(memcpy)
READ (memcpy)
Basically I write on the AXI master interface and then read back the data.
If I make a Cosimulation in Vitis HLS I don't get the reading operation, and the writing one is with WDATA = 'X' as show in the picture:
I think this is a really simple example writing and then reading, what's wrong?
Thank you for your help
11-19-2020 02:12 AM
Hi @namabo ,
you are working with the buff variable not initialized. Setting buff as static solve the problem.
Cheers.
11-19-2020 02:12 AM
Hi @namabo ,
Cheers.
11-19-2020 02:46 AM
Thank you @dsakjl ,
this solve the proble!
