Building Xilinx Binary Neural Network in HLS Error on Windows Machine.
I am trying to build the Xilinx BNN HLS code from here: https://github.com/DjImene/Xilinx-BNN-PYNQ
In the repo, there is a section named "Hardware Design Rebuild".
I followed the instruction there, and when I issue following command, I got an error.
> make-hw.sh cnv-pynq pynq a
But, I am getting following error. Is there any suggestions to pass this error ?
I am on Windows machine and using Vivado HLS 2016.4.
----------------------------------------Here is the error that I get---------------------------------------------
WARNING: [HLS 200-40] In file included from ../../cnv-pynq/hw/top.cpp:42:
In file included from C:/projects/Xilinx-BNN-PYNQ/bnn/src//library/hls\bnn-library.h:43:
In file included from C:/Xilinx/Vivado_HLS/2016.4/include\hls_stream.h:79:
In file included from C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\queue:60:
In file included from C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\deque:61:
In file included from C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\bits/allocator.h:48:
In file included from C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2/x86_64-w64-mingw32\bits/c++allocator.h:34:
In file included from C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\ext/new_allocator.h:33:
In file included from C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\new:41:
In file included from C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\exception:150:
C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\exception_ptr.h:132:13: error: unknown type name 'type_info'
const type_info*
In file included from C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\exception:151:
C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\nested_exception.h:62:5: error: the parameter for this explicitly-defaulted copy constructor is const, but a member or base requires it to be non-const
nested_exception(const nested_exception&) = default;
C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\nested_exception.h:64:23: error: the parameter for this explicitly-defaulted copy assignment operator is const, but a member or base requires it to be non-const
nested_exception& operator=(const nested_exception&) = default;
C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\nested_exception.h:77:28: error: exception specification in declaration does not match previous declaration
inline nested_exception::~nested_exception() = default;
C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\nested_exception.h:66:20: note: previous declaration is here
inline virtual ~nested_exception();
C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\nested_exception.h:122:61: error: redefinition of default argument
__throw_with_nested(_Ex&& __ex, const nested_exception* = 0)
C:/Xilinx/Vivado_HLS/2016.4/win64/tools/clang/bin\..\lib\clang\3.1/../../../include/c++/4.5.2\nested_exception.h:110:56: note: previous definition is here
__throw_with_nested(_Ex&&, const nested_exception* = 0)
5 errors generated.
ERROR: [HLS 200-70] Compilation errors found:
Pragma processor failed: In file included from ../../cnv-pynq/hw/top.cpp:42:
const type_info*
5 errors generated.
Failed checking during preprocessing.
while executing
"source C:/projects/Xilinx-BNN-PYNQ/bnn/src/network/output/hls-syn/cnv-pynq/sol1/csynth.tcl"
invoked from within
"hls::main C:/projects/Xilinx-BNN-PYNQ/bnn/src/network/output/hls-syn/cnv-pynq/sol1/csynth.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
Re: Building Xilinx Binary Neural Network in HLS Error on Windows Machine.
I meet the same issue. when I use -std=c++0x flags, BNN compile failured.
