C Synthesis on Vitis HLS with systemC
Dear all,
I'm trying to create a block on Vitis HLS using systemC.
During the C Simulation, everything goes well but when I try to run the C synthesis, I have the error below :
ERROR: [HLS 200-637] SystemC input is not supported
SystemC is not supported!
while executing
"source XXX/7_Segments/initial/csynth.tcl"
invoked from within
"hls::XXX/7_Segments/initial/csynth.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
"hls_proc $argv"
The objective is to create a block ip to switch on four leds with a switchs.
#include <iostream>
#include <systemc.h>
using namespace std;
#include"test.cpp"
int sc_main (int argc , char *argv[]){
	counter* cnt;
	instance(cnt);
	return 0;
7_segment_tb.cpp (test bench)
#ifndef __SEGMENT__
#define __SEGMENT__
#include "ap_int.h"
//void instance(counter* cnt, sc_signal <bool> clk, sc_signal <sc_uint<1>> swt[4], sc_signal <sc_uint<1>> led[4]);
SC_MODULE(counter){
	//Ports :
	 sc_in <bool> clock;
	 sc_in <sc_uint<1>> swt[4];
	 sc_out<sc_uint<1>> led[4];
	void switch_to_led();
	//Constructor
	SC_CTOR(counter){
		SC_METHOD(switch_to_led);
	    sensitive_pos << clock;
#endif
7_segment.h
#include "7_segment.h"
void counter::switch_to_led(){
		led[0].write(swt[0].read());
		led[1].write(swt[1].read());
		led[2].write(swt[2].read());
		led[3].write(swt[3].read());
7_segment.cpp
inline void instance(counter* cnt){
	sc_signal <bool> clk;
	sc_signal <sc_uint<1>> swt[4];
	sc_signal <sc_uint<1>> led[4];
	cnt = new counter("Counter");
	cnt->clock(clk);
	for(int i = 0; i<4; i++){
		cnt->swt[i](swt[i]);
		cnt->led[i](led[i]);
test.cpp (instance is my top function)
Could you please help me with this issue ?
Adri
Hi @Adri
Unfortunately System C support is deprecated in Vitis HLS. Please see the following AR for details:
https://www.xilinx.com/support/answers/73613.html
If your design includes IP blocks generated by Vivado HLS based on a SystemC source description, you will still be able to reuse these blocks in the 2020.1/2020.2 tools (IP Integrator and Vivado).
If you wish to continue designing with SystemC, one option is to use a third-party SystemC high-level synthesis tools.
Aoife
Hi @aoifem ,
Many thanks for your answer.
Could you tell me why SystemC is depreciated in Vitis HLS, please ?
Adri
Hi @Adri
The decision was a marketing decision so I'm not sure on the details. It could have been that there was more demand for C and C++ solutions.
Aoife
