Observer alexkroh
Can't assign m_axi interface for global array
I have am using HLS to synthesize a function that uses a global array that is shared by other functions. As such, the IP must provide an interface for accessing shared memory rather than instantiating internal storage resources.
A simplified representation of the function is below.
volatile char buf[1024];
void my_top_function(char* in, char* out){
#pragma HLS INTERFACE m_axi depth=1 latency=12 port=buf offset=slave bundle=gmem
#pragma HLS INTERFACE m_axi depth=1 latency=12 port=out offset=slave bundle=gmem
#pragma HLS INTERFACE m_axi depth=1 latency=12 port=in  offset=slave bundle=gmem
#pragma HLS INTERFACE s_axilite port=return bundle=cntrl
	int i;
	for(i = 0; i < BUF_SIZE; i++){
		out[i] = in[i] + buf[i];
	return;
My understanding is that the directive that I have used for "buf" should result in buf being accessed via the gmem master interface of the IP. A register accessible via the s_axilite interface should provide the offset of the array.
Unfortunately, the generated driver does not provide a method for assigning this offset, and I see no attempt to access "buf" on "gmem" when using the debug probes.
Is this a bug in my code or a bug in Vivado HLS?
Thanks in advance,
 - Alex
Observer alexkroh
Re: Can't assign m_axi interface for global array
Turns out it is neither.
From the menus: Solution->Solution settings
Under "general", add the command "config_interface".
In the parameters for this command, option "expose_global" must be checked.
Observer alexkroh
