Participant futuristic
Co-Simulation Fail
Folks,
I am getting a Co-Simulation fail for my design.
It is not straight forward to trace the error as different Vivado HLx version return different error messages.
Vivado 2017.2:  Simulation passes.
CoSimulation failes with the follwoing error:
[SIM-360] Aborting co-simulation: C TB simulation failed.
[SIM-320] C TB testing failed, stop generating test vectors. Please check C TB or re-run cosim.
[SIM-4] *** C/RTL co-simulation finished: FAIL ***
Vivado 2018.2 and 2018.3: simulation passes.
CoSimulation failes with the following error: (Even example designs fail for CoSimulation :( )
WARNING: [COSIM 212-369] AXI_master port 'a' has a depth of '123456'. Insufficient depth may result in simulation mismatch or freeze.
ERROR: [COSIM 212-317] C++ compile error. ERROR: [COSIM 212-321] EXE file generate failed. ERROR: [COSIM 212-321] EXE file generate failed. ERROR: [COSIM 212-331] Aborting co-simulation: C simulation failed, compilation errors
So, anyone had the same problem and how to solve it?
Cheers,
Re: Co-Simulation Fail
Hi @futuristic,
can you please check and confirm if the testbench array size and design array size is the same, this might be the case for the co-simulation failure.
@shameeraYes, they are the same.  My code follows similar format as below.
Testbench:
a = (int*)malloc(123456);
Design Interface:
#pragma HLS INTERFACE m_axi port = a depth=123456 offset = slave bundle = xx register
