Visitor fkautz
Concat multiple IPs using Axi Stream Interface
Hey,
I have problems with concatenating three IP cores using Axi Streaming Interface.
Descrition of the situation wanted:
IP1 gets the datastream from the DMA, works with the data and passes the new stream to IP2.
IP2 is working on the data and passes the datastream to  IP3.
IP3 works with the data, passes the datastream to the DMA which then maps the data to the RAM.
Now the description of the problem:
Everything described above works fine with 2 IP cores. After adding a third IP no correct result is calculated.
I verified all the IPs. They are all doing what they are supposed to do.
What could be the reason for this situation. Is there a need for a buffer or someting? I also have no timing issues in vivado or some such.
BR
Scholar drjohnsmith
Re: Concat multiple IPs using Axi Stream Interface
should work , but
try putting axi fifo's between all the blocks,
    allows back pressure,
you also have the AXI debugging cores you could install.
have you tried simulating ?
    you should be able to see if there is any back pressure then,
Scholar drjohnsmith
should work , but
Scholar jprice
This issue should show up in HDL simulations or in hardware with chipscope or ILA. You should be able to check that IP1 receives and consumes data and passed it to IP2 and to IP3 and back to RAM. Something in that chain broke and you should be able to observe it. .
Visitor fkautz
At first thank you for your feedback.
I will give all the suggestions given a try and be right back to report my status.
BR
Visitor fkautz
Hey,
I solved the problem by adding an Axi4-Stream-Data-FiFo between the second and the third IP and with changing the position in my software in which I started the IP core itself.
Thank you for your help!
BR
