Create testbench From C++ code.
Hi to all
I have the following working  cpp Code that removes all red pixel from a picture.I want to implement it in Vivado HLS but i don not know how to create a testbench fot this code...
Can you show me a way or a guide to create the testbench?
Thanks in advance!
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
#define SIZE 64*64*4
unsigned char INPUT_RGBA[64 * 64 * 4];
unsigned char OUTPUT_RGBA[64 * 64 * 4];
int main(int argc, char *argv[])
	unsigned int line_counter = 0;
	unsigned int i = 0;
	unsigned char temp;
	FILE *rFILE ;
	char in_filename [1024] ;
	FILE *wFILE ;
	char out_filename[] = "out.rgba" ;
	strcpy (in_filename, argv[1] );
 	rFILE = fopen(in_filename,"rb");
	wFILE = fopen(out_filename,"wb");
	if ( (rFILE == NULL) || (wFILE == NULL))
		// segnematation fault
		exit(0);
// initializationn part: read the input rgba file and store the results to INPUT_RGBA array
	for(i = 0; i < SIZE; i++) {
		fscanf(rFILE,"%c", &temp);
		INPUT_RGBA[i] = temp;
// processing part: INPUT_RGBA --> some kind of processing OUTPUT_RGBA
		if (i % 4 == 0) {
			OUTPUT_RGBA[i] = 0 ;
	        else {
			OUTPUT_RGBA[i] = INPUT_RGBA[i] ;
// store the results to output file: print the OUTPUT_RGBA to a wFILE
	for(i = 0; i < 64 * 64 * 4 ; i++) {
		fprintf(wFILE,"%c", OUTPUT_RGBA[i]) ;
	fclose(rFILE);
	fclose(wFILE);
	return 0;
Advisor
Advisor
Right, so at the moment your code is all-in-one testbench and "functional" code. If we split it up:
Testbench initialization
	unsigned int i = 0;
	unsigned char temp;
	FILE *rFILE ;
	FILE *wFILE ;
		exit(0);
Functional code
		if (i % 4 == 0) {
	        else {
Testbench clean-up
	fclose(rFILE);
	fclose(wFILE);
	return 0;
So, what you want to do is something like this:
testbench.cpp
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
process(unsigned char * in, unsigned char * out);
	unsigned int i = 0;
	unsigned char temp;
	FILE *rFILE ;
	FILE *wFILE ;
		exit(0);
	process (INPUT_RGBA, OUTPUT_RGBA);
	fclose(rFILE);
	fclose(wFILE);
	return 0;
process.cpp:
void process(unsigned char * INPUT_RGBA, unsigned char * OUTPUT_RGBA) {
		if (i % 4 == 0) {
	        else {
Once you get closer to synthesis you'll want to think about interface types. Will this block be pulling data straight from off-chip RAM? Will it be getting an image stream from a camera? Those will determine just how you do your interfaces and what restrictions are put on the block.
Advisor
Advisor
	unsigned int i = 0;
	unsigned char temp;
	FILE *rFILE ;
	FILE *wFILE ;
		exit(0);
Functional code
		if (i % 4 == 0) {
	        else {
Testbench clean-up
	fclose(rFILE);
	fclose(wFILE);
	return 0;
testbench.cpp
#include <stdio.h>
#include <string.h>
#include <stdlib.h>
	unsigned int i = 0;
	unsigned char temp;
	FILE *rFILE ;
	FILE *wFILE ;
		exit(0);
	fclose(rFILE);
	fclose(wFILE);
	return 0;
process.cpp:
		if (i % 4 == 0) {
	        else {
@scholar
Thanks a lot my friend!!!
