mathieu.lebon
Design viewer in tcl
I can run the cosimulation from a tcl script (cosim_design),
but is it also possible to open the design viewer from this script ?
Mathieu
arpansur
Hi @mathieu.lebon,
Please try the below steps:
  1. cosim_design -trace_level all
    Above command will create a folder solution1/sim/verilog.
  2. The above folder will have .wdb file
  3. Create a Tcl file say "open_wave.tcl" in the solution1/sim/verilog folder.
  4. Add below lines to newly created "open_wave.tcl"
    current_fileset
    open_wave_database <wdb file name>.wdb
  5. After step-4 use below commands:
    cd <folder name>\solution1\sim\verilog
    C:\Xilinx\Vivado\2016.3\bin\vivado.bat -source open_wave.tcl
Arpan
arpansur
Hi @mathieu.lebon,
You can open the project using vivado_hls -p <project name>
Arpan
mathieu.lebon
Hi Arpan,
Yes thanks for your help. Indeed, that's what I did.
It would have been great to be able to open the wave from the tcl.
By the way, I run the co-simulation (cosim_design) from the tcl, but when I open the project (using the -p option) I have to run the co-simulation again in the gui, otherwise the wave viewer is not available.
Mathieu
arpansur
Hi @mathieu.lebon,
    current_fileset
Arpan
mathieu.lebon
Thanks Arpan, it works great.
That's exactly what I was looking for.
Mathieu
