Observer tobinhall
Detecting axi writes with AP_none
I have 2 scenario that seem to have the same root issue/requirement.  Because I am building an engine and not a algorithm accelerator, I am using AP_none.
1. Autoresetting bit using an Axi slave port.  APU sets a bit and HLS clears it.
2. Wait for input HLS comes to a point where Data is required from the APU before proceeding and I don't want stale data. (this is sort of a Variant of #1 as I could Write some uninitialized value and wait for it to change.)
I have seen some solutions for older versions of HLS that appear to implement memory, but I'm not sure that they are done the same way on 2017.1.
Tobin.
Voyager
Voyager
Re: Detecting axi writes with AP_none
Hey Tobin,
2 single writes are NOT preferred in attempting to signal HLS.
I don't think HLS provides other AXI Lite interfaces or handshakes ...
Probably the easiest way is to create a simple AXI Lite slave which maps each write/read transaction to the typical HLS bus interface with handshake. This way you can still connect everything in block design and a single write/read will trigger the HLS generated IP.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
Observer tobinhall
Just to clarify I am using AP_ctrl_none and need an axi slave port/address to perform the function.
Voyager
Voyager
Hey Tobin,
I'm not sure I understand what you want to do. Maybe you can give an example?
Anyway, the following HLS code creates AXI Lite in/out ports with handshake ...
#include <ap_int.h>
typedef ap_uint<32> reg_t;
void slave(reg_t *I, reg_t *Q) {
    #pragma HLS INTERFACE s_axilite port=I,Q
    #pragma HLS INTERFACE ap_hs port=I
    #pragma HLS INTERFACE ap_vld port=Q
    #pragma HLS INTERFACE ap_ctrl_none port=return
    *Q = *I;
... note that this will result in the following registers ...
-- ------------------------Address Info-------------------
-- 0x00 : reserved
-- 0x04 : reserved
-- 0x08 : reserved
-- 0x0c : reserved
-- 0x10 : Data signal of I_V
--        bit 31~0 - I_V[31:0] (Read/Write)
-- 0x14 : Control signal of I_V
--        bit 0  - I_V_ap_vld (Read/Write/COH)
--        bit 1  - I_V_ap_ack (Read)
--        others - reserved
-- 0x18 : Data signal of Q_V
--        bit 31~0 - Q_V[31:0] (Read)
-- 0x1c : Control signal of Q_V
--        bit 0  - Q_V_ap_vld (Read/COR)
-- (SC = Self Clear, COR = Clear on Read, TOW = Toggle on Write, COH = Clear on Handshake)
Hope this helps,
Herbert
Observer tobinhall
The control signals here are of the APU, not for HLS.
Here I(0x10) and Q(0x18) are different Axi Addresses. I need them to control the same address, like memory. In other words Can HLS write I? (APU Sets I HLS clears I).
To put it another way, can HLS detect a write of the same value to the same address from the APU's perspective? (think of a self resetting register that changes on read or write such as many interrupt flag implementations)
Observer tobinhall
In my particular application I am trying to have the APU repeatedly atomically signal HLS. 2 single writes is are preferred for performance reasons.
Observer tobinhall
eye!!! my typing is getting in the way... 2 single writes are NOT preferred in attempting to signal HLS
Voyager
Voyager
Hey Tobin,
Hope this helps,
Herbert
