Participant futuristic
@E Simulation failed: SIGSEGV.
Ok, @E Simulation failed: SIGSEGV error is driving me crazy. I am having trouble pin pointing what caused it. Please have a look a the code below.
int *Mem;
int *Mem1;
int *Mem2;
void allocate_mem()
	int kSize = (k) * sizeof(int);
        int pSize = (p) * sizeof(int);
	int tSize = kSize + pSize;
	Mem = (int*)malloc(tSize);
	Mem1 = (int*)Mem;
	Mem2 = (int*)(Mem + kSize);
int main()
    int a = x*sizeof(int);
    int b = y*sizeof(int);
    int* addrA = (int*)malloc(x*sizeof(int));
    int* addrB = (int*)malloc(y*sizeof(int));
    FILE* filePtr;
    filePtr = fopen("~/input.bin", "rb");
    fread(addrB, sizeof(int), b, filePtr);
    fclose(filePtr);
    memcpy(Mem2, addrB, b);
    return 0;
When debugging the segmentation error comes form the below line.
memcpy(Mem1, addrB, b); // Works fine but the Mem1 block has been loaded its own input from a different file
 I have checked for Mem2 and addrB not returning NULL. Also checked the number of elements from fread(...). Everything seems ok for me but HLS is still throwing the @E Simulation failed: SIGSEGV error. This error won't happen if I select "Build Only".
Here is also the message from the debugging:
Breakpoint 1, main () at ../../../topmain.cpp:107
107		memcpy(Mem2, addrB, b);
Program received signal SIGSEGV, Segmentation fault.
0x0040167d in main () at ../../../topmain.cpp:107
[Thread 10808.0x1838 exited with code 3221225477]
[Inferior 1 (process 10808) exited with code 030000000005]
Quit (expect signal SIGINT when the program is resumed)
Any comment is appreciated.
Cheers!
Scholar u4223374
Re: @E Simulation failed: SIGSEGV.
Ah, I think I have it!
When you add a value to a pointer, C shifts that many elements through memory, not that many bytes. If you do this:
Mem2 = Mem + N;
then (assuming Mem is an int* and sizeof(int) = 4) Mem2 will end up N elements further through RAM, which is 4N bytes.
You're adding kSize, so the number of bytes shifted is actually kSize * sizeof(int) = k * sizeof(int) * sizeof(int)...
The fix is easy:
Mem2 = (int*)(Mem + k);
Scholar hbucher
@futuristic  What are the values of x and y?
Print/check the pointers you get from malloc. It might be too big and failing, returning NULL.
x(25050) and y(784).
Bytes allocated: 102280B (Mem1) + 3136B (Mem2)
Memory region: 14524392 to 14946056
And Mem is pointing to 14524392.
Scholar u4223374
The obvious issue I can see in your code is that you never actually call allocate_mem(), so Mem2 will not be initialized.
This shouldn't be causing the problem, but are you sure your array sizes are right?
You start with y = 784, then you multiply that by sizeof(int) (ie 4) to get b = 3136, and then you malloc b*sizeof(int) bytes (ie y * sizeof(int) * sizeof(int) bytes). You also ask fread to read (y * sizeof(int)) elements, each with size sizeof(int), again reading y * sizeof(int) * sizeof(int) bytes. However, when you're copying into mem2, you only copy y * sizeof(int) bytes.
That may be completely intentional, it just looks a bit strange.
Yeah that is because I customized my code to post it here. I call the allocate_mem() actually.
You are right on the array size. I have edited it.
But why is it not having segmentation issue when memcpy(Mem1, addrB, b); or memcpy(Mem, addrB, b); (even though that is not what I wanted to do)
HLS throws the error only when asking to copy to Mem2. memcpy(Mem2, addrB, b);
Scholar u4223374
Mem2 = Mem + N;
The fix is easy:
That is exactly right. Solved it! Thanks!
