ERROR: [HLS 200-70] Failed building synthesis data model. command 'ap_source' returned error code
I am getting error as below
How to solve it?
Starting C synthesis ...
D:/Vivado/2018.3/bin/vivado_hls.bat D:/sesha_vivado_files/sesha_paillier_encry/solution1/csynth.tcl
INFO: [HLS 200-10] Running 'D:/Vivado/2018.3/bin/unwrapped/win64.o/vivado_hls.exe'
INFO: [HLS 200-10] For user 'sarve' on host 'desktop-p0fab73' (Windows NT_amd64 version 6.2) on Tue Oct 15 10:54:59 +0800 2019
INFO: [HLS 200-10] In directory 'D:/sesha_vivado_files'
INFO: [HLS 200-10] Opening project 'D:/sesha_vivado_files/sesha_paillier_encry'.
INFO: [HLS 200-10] Adding design file 'sesha_paillier_encry/paillier.cpp' to the project
INFO: [HLS 200-10] Opening solution 'D:/sesha_vivado_files/sesha_paillier_encry/solution1'.
INFO: [SYN 201-201] Setting up clock 'default' with a period of 10ns.
INFO: [HLS 200-10] Setting target device to 'xcvu095-ffva2104-2-e'
INFO: [SCHED 204-61] Option 'relax_ii_for_timing' is enabled, will increase II to preserve clock frequency constraints.
INFO: [HLS 200-10] Analyzing design file 'sesha_paillier_encry/paillier.cpp' ...
INFO: [HLS 200-111] Finished Linking Time (s): cpu = 00:01:35 ; elapsed = 00:03:10 . Memory (MB): peak = 243.477 ; gain = 158.512
INFO: [HLS 200-111] Finished Checking Pragmas Time (s): cpu = 00:01:35 ; elapsed = 00:03:10 . Memory (MB): peak = 243.477 ; gain = 158.512
INFO: [HLS 200-10] Starting code transformations ...
INFO: [HLS 200-111] Finished Standard Transforms Time (s): cpu = 00:01:41 ; elapsed = 00:03:17 . Memory (MB): peak = 400.570 ; gain = 315.605
INFO: [HLS 200-10] Checking synthesizability ...
WARNING: [SYNCHK 200-23] sesha_paillier_encry/paillier.cpp:158: variable-indexed range selection may cause suboptimal QoR.
INFO: [SYNCHK 200-10] 0 error(s), 1 warning(s).
INFO: [HLS 200-111] Finished Checking Synthesizability Time (s): cpu = 00:01:42 ; elapsed = 00:03:18 . Memory (MB): peak = 406.715 ; gain = 321.750
INFO: [XFORM 203-11] Balancing expressions in function 'mod_mult_2048' (sesha_paillier_encry/paillier.cpp:38:42)...7 expression(s) balanced.
INFO: [HLS 200-111] Finished Pre-synthesis Time (s): cpu = 00:01:45 ; elapsed = 00:03:21 . Memory (MB): peak = 457.848 ; gain = 372.883
while executing
"source D:/sesha_vivado_files/sesha_paillier_encry/solution1/csynth.tcl"
invoked from within
"hls::main D:/sesha_vivado_files/sesha_paillier_encry/solution1/csynth.tcl"
("uplevel" body line 1)
invoked from within
"uplevel 1 hls::main {*}$args"
(procedure "hls_proc" line 5)
invoked from within
"hls_proc $argv"
0x00007FF90B34F4E8 (0x000001D563185020 0x00007FF90B350EA9 0x000001D3CCDA52F0 0x00007FF944C0083D), ?main@Syn@@YAHHPEAPEAD@Z() + 0x37F598 bytes(s)
0x00007FF90B34DBA7 (0x0000000000000000 0x000001D3C49148C0 0x000001D3C49148C0 0x000001B000000000), ?main@Syn@@YAHHPEAPEAD@Z() + 0x37DC57 bytes(s)
0x00007FF90B34EB55 (0x0000000000000000 0x00007FF90BDD77B0 0x000001D3C03E1330 0x000001D3C27EDB00), ?main@Syn@@YAHHPEAPEAD@Z() + 0x37EC05 bytes(s)
0x00007FF90B2DF802 (0x0000000000000000 0x00007FF90AF35F72 0x000001D3C0383A60 0x00007FF90C7B72E2), ?main@Syn@@YAHHPEAPEAD@Z() + 0x30F8B2 bytes(s)
0x00007FF90B3C5125 (0x000001D3C03E1568 0x00007FF90BEE1E60 0xFFFFFFFFFFFFFFFE 0x000001D300000000), ?main@Syn@@YAHHPEAPEAD@Z() + 0x3F51D5 bytes(s)
0x00007FF90BEE1D42 (0x000001D3C03E15A0 0x000001D3C03E1578 0x000001D3C03E3740 0x000001D3C03E1330), exp2() + 0x344482 bytes(s)
0x00007FF942AF9D06 (0x0000000000000000 0x000000374C7FEBB8 0x000000374C7FEE70 0x00007FF942BCBC20), _execute_onexit_table() + 0x156 bytes(s)
0x00007FF942AF9C2B (0x0000000000000000 0x0000000000000001 0x000001D3BE831590 0x000000374C7FEBA8), _execute_onexit_table() + 0x7B bytes(s)
0x00007FF942AF9BE4 (0x00007FF90C427AD0 0x000001D300000002 0x00007FF900000002 0x000000374C7FEBA0), _execute_onexit_table() + 0x34 bytes(s)
0x00007FF90BDD762E (0x0000000000000001 0x000000374C7FEE00 0x0000000000000001 0x00007FF941980000), exp2() + 0x239D6E bytes(s)
0x00007FF90BDD7724 (0x00007FF90AEF0000 0x0000000000000000 0x0000000000000001 0x000000007FFE0385), exp2() + 0x239E64 bytes(s)
0x00007FF944BE50A1 (0x000001D3C05AA6B0 0x00007FF90AEF0000 0x00007FF900000000 0x000001D3C05AA6D0), RtlActivateActivationContextUnsafeFast() + 0x121 bytes(s)
0x00007FF944C2AB02 (0x0000000000000001 0x000001D3BE8368D0 0x0000000000000000 0x0000000000000002), LdrShutdownProcess() + 0x132 bytes(s)
0x00007FF944C2A9AD (0x0000000000000001 0x000001D3BE8368D0 0x00007FF942B99B68 0x0000000000000000), RtlExitUserProcess() + 0xAD bytes(s)
0x00007FF94396CD8A (0x0000000000000001 0x0000000000000000 0x000000374C7FEE58 0x00007FF942BCBC20), ExitProcess() + 0xA bytes(s)
0x00007FF942AFAE38 (0x0000000000000001 0x000001D300000000 0x0000000000000000 0x000000374C7FEE50), _o_free() + 0x178 bytes(s)
0x00007FF942AF86EF (0x0000000000000001 0x000001D300000000 0x0000000000000000 0x0000000000000001), exit() + 0x7F bytes(s)
0x0000000053A13393 (0x000001D3BE831590 0x000001D3BE8238F0 0x000000374C7FEE20 0x000000374C7FEE28), Tcl_Exit() + 0x63 bytes(s)
0x00000000539DAEBA (0x0000000053AD5A20 0x0000000000000000 0x00007FF900000001 0x0000000053A9AC3C), TclDumpMemoryInfo() + 0x34EA bytes(s)
0x00000000539D11FC (0x0000000000000000 0x000001D300000002 0x000001D3BE8368D0 0x00007FF90CBC7980), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x00000000539D218E (0x000001D3BE831590 0x00007FF90CBC7980 0xFFFFFFFF00000002 0x00007FF900000002), Tcl_EvalEx() + 0x99E bytes(s)
0x00000000539D2A38 (0x000001D3C03DDA30 0x0000000000000000 0x000001D3C03DDA10 0x0000000000000000), Tcl_Eval() + 0x38 bytes(s)
0x00007FF90C959164 (0x000001D3C0342E90 0x000001D300000000 0x000001D3C0351C20 0x000000000000000B), Java_ui_frmwork_commandi_undo() + 0x183E4 bytes(s)
0x00007FF90C9594A7 (0x000001D3C03427F0 0x0000000000000006 0x000000374C7FF768 0x000001D3BE702580), Java_ui_frmwork_commandi_undo() + 0x18727 bytes(s)
0x00007FF910A8C934 (0x000001D3BE831590 0x000000374C7FF768 0xFFFFFFFFFFFFFFFF 0x5F736B7361746E6F), ?eval_in_tcl_throw@task_manager@tcltasks@hdi@@SAHPEBD0_N@Z() + 0x254 bytes(s)
0x00007FF910A8F746 (0x65732F73656C6966 0x6C6961705F616873 0x636E655F7265696C 0x74756C6F732F7972), ?retrieve_except_msg_instance@task_manager@tcltasks@hdi@@SA_NAEAV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@@Z() + 0x4C6 bytes(s)
0x00000000539D11FC (0x0000003700000000 0x000000000000000B 0x000001D3BE84AF10 0x0000000000000000), Tcl_ListMathFuncs() + 0x58C bytes(s)
0x00000000539D1681 (0x000001D3BE82C7D0 0x000000000000000B 0x0000000000000001 0x000000374C7FFB79), Tcl_EvalObjv() + 0x51 bytes(s)
0x00000000539D2C37 (0x000000000000000B 0x000000374C7FFB79 0x000000000000000B 0x000001D3BE831590), TclEvalObjEx() + 0x157 bytes(s)
0x00000000539D2ACD (0x0000000000000050 0x0000000000000000 0x0000000000000050 0x000001D3BE828F00), Tcl_EvalObjEx() + 0x1D bytes(s)
0x00007FF9116046AA (0x000001D3BE82BC90 0x000001D3BE82BC90 0x000001D3BE831590 0x0000000000000000)
0x0000000053A46BE1 (0x000001D3BE792080 0x00007FF941AA2FE0 0x00007FF942B99B68 0x0000000000000000), Tcl_Main() + 0x471 bytes(s)
0x00007FF910ABADE9 (0x000001D3BE792080 0x0000000000000000 0x0000000000000000 0x0000000000000000), ?join@HCTNativeThread@@QEAAXXZ() + 0x39 bytes(s)
0x00007FF942B00E72 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), _beginthreadex() + 0x142 bytes(s)
0x00007FF943967BD4 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), BaseThreadInitThunk() + 0x14 bytes(s)
0x00007FF944C2CED1 (0x0000000000000000 0x0000000000000000 0x0000000000000000 0x0000000000000000), RtlUserThreadStart() + 0x21 bytes(s)
Abnormal program termination (EXCEPTION_ACCESS_VIOLATION)
Please check 'D:/sesha_vivado_files/hs_err_pid6152.log' for details
Finished C synthesis.
Re: ERROR: [HLS 200-70] Failed building synthesis data model. command 'ap_source' returned error code
HI @chandu_sathi ,
From the error, it seems Vivado HLS 2018.3 got crashed when trying to synthesize your design.
Please give a try in Vivado HLS 2019.1 version. If you still see the same issue there too then please share us your design for debugging further.
HI @chandu_sathi ,
