assaf_malki
FCUDA using AutoESL Autopilot
Hey guys,
I'm interested in transforming CUDA -C to RTL and implement it on one of Xilinx FPGA.
I found an article which shows how it can be done using AutoESL Autopilot application.
From what I understand, Xilinx acquired AutoSEL.
What about Autopilot, is it implemented in the VIVADO?
If so, can I specify it to target CUDA - C?
Thanks a lot.
Assaf.
athandr
Xilinx aquired the AUTOESL and we use it with a name of VivadoHLS. You can search the Vivado HLS documents on web for your requirement. However i will be moving it to the required board so that you can get some suggestions.
Anirudh
debrajr
AutoESL is known as Vivado HLS now. Refer to link: http://www.xilinx.com/products/design-tools/vivado/integration/esl-design/index.htm and yes you can use this tool to convert your C/C++/System C to Verilog/VHDL.
Debraj
