thisisbaback
FIFO data count in Vivado HLS
Hello everyone!
I'm designing an IP-Core with Vivado HLS. I have a stream in my design, and I have added the following pragma in my top-level to store that in a FIFO. st_out1 is derived in a function called in the top function.
#pragma HLS STREAM variable=st_out1 depth=2048 dim=1
I want to read this FIFO's data count, and make decisions with respect to this number. I've used the function size(), and it is definitely the data count. It increases by 1 after each write(), and decreases by 1 after each read(). But this can't be synthesized, and the synthesizer reports the size() function can be used only in simulation. The error is like:
ERROR: [XFORM 203-733] Function hls::stream::size() (top.cpp:20:18) is not synthesizable, it can only be used in C simulation.
ERROR: [HLS 200-70] Pre-synthesis failed.
What can I do for this porpuse? How can I measure a stream's data count?
thisisbaback
I've done this task by making my own data count. But I really like to know if there's a way to measure the data count of a stream in Vivado HLS.
thisisbaback
