Observer lin.zhang
Floating point core using HLS
Hi all,
I used Vivado HLS 14.5 in Ubuntu 12.04 64-bit,  to generate an extremely simple function:
void function_test(float a[9], float b[9], float c[9]){
int i=0;
for(i=0;i<9;i++){c[i]=b[i]+a[i];}
With the following directives:
set_directive_resource -core AXI4LiteS "function_test" a
set_directive_array_partition -type complete -factor 1 -dim 1 "function_test" a
set_directive_resource -core AXI4LiteS "function_test" b
set_directive_array_partition -type complete -factor 1 -dim 1 "function_test" b
set_directive_resource -core AXI4LiteS "function_test" c
set_directive_array_partition -type complete -factor 1 -dim 1 "function_test" c
This core is added into an EDK project and downloaded on a Zedboard, the ap_start of the core is connected to a switch for non-stop running.
The function in HLS has been simulated and works as expected.
My problem is:
I can't write floating point numbers in SDK, I tried type cast etc. but still got the following:
1. Positive floating point numbers, e.g. 1.5, is read as a 1 and written into the register.
2. Negative floating point numbers, e.g. -2.2, is treated as 0.
3. Negative and positive integers are acceptable.
4. Type cast does not work
5. The .c and .h files generated along with the core in "drivers" directory have undefined macros, and the ConfigTable doesn't exist in anyother .c or .h files.
It seems the FPGA only accept int type, both signed and unsigned, how can I write float number?
Wrt problem 5, is there any other directives I should add?
Thanks!
Observer lin.zhang
Re: Floating point core using HLS
I got it solved by using union:
union my_type {
u32 u;
float f;
Observer lin.zhang
I have solved problem 5, by adding "pcores" and "drivers" directories into the repository of SDK.
I made a mistake on the path ..
Observer lin.zhang
union my_type {
u32 u;
float f;
