Visitor mouhamedmbr
Function 'test' could not be resolved in HLS
I have the following errors in test file of my project ,first when when launching the C simulation I have a problems:
INFO: [SIM 2] *************** CSIM start ***************
WARNING: [SIM 51] HLS only supports CLANG compiler in Linux.
INFO: [SIM 4] CSIM will launch GCC as the compiler.
Compiling ../../../../codegen/lib/testtestphase/examples/main.cpp in debug mode
../../../../codegen/lib/testtestphase/examples/main.cpp:33:26: fatal error: rt_nonfinite.h: No such file or directory
compilation terminated.
make: *** [obj/main.o] Error 1
CRITICAL WARNING: [SIM 100] 'csim_design' failed: compilation error(s).
INFO: [SIM 3] *************** CSIM finish ***************
second when I open the file test reports these errors.
multiple markers at this line
-Function 'testph' could not be resolved;
-symbol 'testph'could not be resolved;
#define MCR_SIZE 60
void testtestphase (AXI_VAL in_stream[MCR_SIZE], AXI_VAL out_stream[3*MCR_SIZE], volatile ap_uint<1> *hw_trig)
	// Map ports to Vivado HLS interfaces
	#pragma HLS INTERFACE ap_fifo port=in_stream
	#pragma HLS INTERFACE ap_fifo port=out_stream
	// Map HLS ports to AXI interfaces
	#pragma HLS RESOURCE variable=in_stream  core=AXIS metadata="-bus_bundle INPUT_STREAM"
	#pragma HLS RESOURCE variable=out_stream core=AXIS metadata="-bus_bundle OUTPUT_STREAM"
	#pragma HLS RESOURCE variable=return core=AXI4LiteS metadata="-bus_bundle CONTROL_BUS"
	#pragma HLS INTERFACE ap_none register port=hw_trig
	dut_testtestphase <float, 60, 1*60, 4, 5, 5>(in_stream, out_stream, hw_trig);
	return;
Re: Function 'test' could not be resolved in HLS
@mouhamedmbr
Have you added rt_nonfinite.h to your project?
Nupur
Visitor mouhamedmbr
yes ,i added but the error still
Visitor mouhamedmbr
@Nupur
