HLS C library paths
When I synthesize my Spartan 7 design, I get the following warings
WARNING: [HLS 200-40] Cannot find library 'xilinx/aspartan7/aspartan7_fpv6'. peak_det:solution1 Aug 8, 2019, 2:55:26 PM
WARNING: [HLS 200-40] Cannot find library 'C:/Xilinx/Vivado/2019.1/common/technology/xilinx/aspartan7/aspartan7_fpv6.lib'. peak_det:solution1 Aug 8, 2019, 2:55:24 PM
WARNING: [HLS 200-40] Cannot find library 'xilinx/aspartan7/aspartan7'. peak_det:solution1 Aug 8, 2019, 2:55:24 PM
WARNING: [HLS 200-40] Cannot find library 'C:/Xilinx/Vivado/2019.1/common/technology/xilinx/aspartan7/aspartan7.lib'. peak_det:solution1 Aug 8, 2019, 2:55:24 PM
these paths do not exist on my computer, but take away the prefix "a" in aspartan7, and they are vallid paths. How can I fix these invalid path names?
Hi ritchiew@golighthouse.com ,
     Refer to this topic
     If you are able to select the device which you are looking for, you can safely ignore this warning.
Wen
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
     Refer to this topic
Wen
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply)
Thanks and Regards,
Aoife
