daniel.cogan
HLS Debugger error
Encountered a strange error after a reboot after Windows was forced to power down.  I found a solution so wanted to share.
Launching .Debug has encountered a problem.
Could not determine GDB version using command: gdb --version
daniel.cogan
I initially tried
1) clean during the C simulation build
2) restart HLS
3) copy source and TB to a new project (surprised this didn't work considering what did work).
4) Project settings showed some strange unknown flags for the testbench file. I tried manually removing.
None worked.
Then, I removed the testbench file from the Explorer pane and added it back.  This seemed to clear the strange flags, and debugger now runs.
daniel.cogan
I initially tried
2) restart HLS
None worked.
