thaus_015
HLS : How to convert integer values into floating point ?
Hi!
   Question looks simple but i am not familiar in working in floating point format. So please guide me.
    I wrote a functional block without using compression which contain In-phase (I) Sample = 16 bits & Quadrature (Q) samples =16 bits // Totally IQ = 32 bit value.
Now I am in need to move into compression technique. I need to convert In-phase (I) and Quadrature (Q) samples into floating point format.
1. Subsequently, the samples are presented as a compressed bit sign and a mantissa (e.g., 9-bit) and a shared exponent.
2. The I and Q samples are subsequently compressed to a bit signed mantissa and unsigned exponent.
I have added "#include"math.h" in my function but i dont know how it can be proceeded (done) ? Please suggest me.
joancab
Have you tried a cast?
float x;
x = (float)int_var;
Actually, just assigning an int to a float should perform the operation, maybe with a warning.
thaus_015
Thanks for your reply.
Consider int_var is 2 dimensional array
int_var={0x0001 0x1111                    // I = 16 bits & Q = 16 bits
              0x0010 0x1011
             0x0011 0x1010
             0x0100 0x1001
            0x0101 0x1000
           0x0110 0x0111
            0x0111 0x0110
           0x1000 0x0101
           0x1001 0x0100
          0x1010 0x0011
        0x1011 0x0010
            0x1111 0x0001 }
x=(float) int_var  ///////Will it work ??
joancab
You cannot copy arrays straight away, but a for loop will definitely do the job.
