HLS state machine error trapping
I've written a parser in HLS that is basically a complex state machine. (extract of code below)
I've included some error trapping that should force the state machine to satae SEND_1 whenever (rts & prev_eop) occurs. This does not happen, as proven both in sim,u;ation and in implemented logic.
prev_eop should just be the value of eop on the previous function call, but I've also tried just using eop, which is a primary input. No difference.
Code:
void    hls_parse_packet_64
    bool            reset,                  // Active high synchronous reset
    bool            rts,                    // Data is available
    bool            *rtr,                   // Data can be accepted
    ap_uint<64>     inword,                 // Current input data word
    bool            sop,                    // Start of packet
    bool            eop,                    // End of packet
    ap_uint<128>    *hdr_fifo,              // Data to be written to "header info" FIFO
    bool            *hdr_sop,               // Start-of-packet to the header FIFO
    bool            *hdr_eop,               // End-of-packet to the header FIFO
    bool            hdr_fifo_full           // "header info" FIFO is full
static     bool            prev_eop;               // Value of EOP on last clock
    // Parse the packet
    if (reset)
        state       =   WAIT_FOR_SOP;
    else if (rts & prev_eop)            // Unconditionally go to state SEND_1 after EOP as an error trap
    {                                   // this is OK because we force rtr low when eop occurs
        state       =   SEND_1;
    else
        switch(state)
            case  WAIT_FOR_SOP:                     // 0x00 - wait for start of packet
                rtr_pre     =   !hdr_fifo_full;
        break;
        }   // end switch(state)
        *rtr    =   rtr_pre & !(prev_eop & rts);
        prev_eop    =   eop & rts;
    }   // end if(reset)
What do I need to do to fix this?
wenchen
Hi steve.kemplin@commscope.com
    All the state machine running status can be checked if you have written a c-test bench and debug step by step.
    Check the value of rts and prev_eop when running the debugger.
Wen
**~ Got a minute? Answer our Vitis HLS survey here! ~**
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
