naz_rb
HLS video processing WINDOW and LINEBUFFER concepts
Which Xilinx document(s) provides specification/description with examples for WINDOW/LINEBUFFER concepts? I looked over most of the HLS documentation and could not find that information.
aoifem
Hi @naz_rb
Have you already looked at UG902 and UG1233
UG902 page 68 lists 3 examples available in HLS which use windows and linebuffers.
UG1233 page 13 explains about the Linebuffer template class, and page 11 explains about the Window buffer template class, available as part of the Xilinx xfOpenCV library
I hope that answers your question.
Aoife
**~ Got a minute? Answer our Vitis HLS survey here! ~**
aoifem
Hi @naz_rb
Aoife
naz_rb
@aoifem  Could not find anything in UG902 (2019), the UG1233 just mentiones the has a brief description of window and linebuffer classes. I remember, 2-3 years ago I saw a nice example (besides edge detection example) that showed how to do general convolution with zeropadding, or someting like that. Maybe that was a TRD or SDSoC documentation. Still looking for it.
p27803
In chapter 3 of UG902 (v2019.1), there is a section titled "Hardware Efficient C Code" that shows some uses line buffers for convolution and nicely handles the border pixels, etc.  This example (or something very similar) has been in several versions of UG902.
naz_rb
Yep, I have seen that one, but it of someting else. I think there was also a code example...
aoifem
Hi @naz_rb
Did you aready look at the coding examples in UG902 page 68 and 69 that were highlighted in the first post?:
Aoife
