Newbie ka367
Houghlines transform.- Generated HLS stream has leftover data warnings , that casue problem in RTL hanging
We are trying to implement hough transfom and mark lanes on a output image. The problem we face here is, we are able to generate outputs, but after the compilation we get the below warning.
WARNING: Hls::stream 'hls::stream<unsigned char>.30' contains leftover data, which may result in RTL simulation hanging.
WARNING: Hls::stream 'hls::stream<unsigned char>.29' contains leftover data, which may result in RTL simulation hanging.
As per our understanding we think I error might be because the canny_edges2 and canny_edges5 stream are not comsumed into another functions/outputs. Any help on how to solve this problem is appreciated. Please note we have used all necessary header files.
Below is the code from streaming input image to output image stream.
#pragma HLS dataflow
// AXI to RGB_IMAGE stream
hls::AXIvideo2Mat( input, src );
hls::Duplicate(src, f1, f2);
// Grayscaling
hls::CvtColor<HLS_RGB2GRAY>( f1, src_bw );
// Gaussian Blur Noise Reduction
hls::GaussianBlur<5,5>( src_bw, src_blur, 1.4, 1.4 );
// Duplicate the streams
hls::Duplicate( src_blur, src1, src2 );
// Calculate gradients in x and y direction using Sobel filter
hls::Sobel<1,0,3>( src1, sobel_gx );
hls::Sobel<0,1,3>( src2, sobel_gy );
// Calculate gradient magnitude and direction
gradient_decomposition( sobel_gx, sobel_gy, grad_gd );
// Perform non-maximum suppression for edge thinning
nonmax_suppression( grad_gd, suppressed );
// Perform hysteresis thresholding for edge tracing
hysteresis( suppressed, canny_edges, 50, 140 );
hls::Duplicate( canny_edges, canny_edges1, canny_edges2); //making multiple copies of canny edges for future purposes
hls::Polar_< ap_fixed<16,3>, ap_fixed<12,12> > lines[500]; //Hough transform
hls::HoughLines2<1, 5>(canny_edges1, lines, 500);
hls::Scalar<3, unsigned char>pixelh; //pixel to add to hough image
hls::Scalar<3, unsigned char>pixela; //pixel to read image
for(pxtype y=0;y<480;y++)
for(pxtype x=0;x<640;x++)
canny_edges2 >> pixela;
p=0;
if(pixela.val[0] != 0)
for(int i=0;i<500;i++)
cordic(lines[i].angle, s, c);
y0 = (lines[i].rho - x*c) /s;
d = y-y0;
if(( d<=0) && ( y > 240))
//if((d <= 500) && (y > 540 && (x <350 || x> 1300)))
p = 1;
if(p==1)
pixelh.val[0] = 255;
else
pixelh.val[0] = 0;
else
pixelh.val[0] = 0;
canny_edges5 << pixelh;
hls::Scalar<3, unsigned char> color(0,0,255);
hls::PaintMask(f2,canny_edges5,f3,color);
// RGB_IMAGE to AXI stream
hls::Mat2AXIvideo(f3, output );
Observer deepeshprakash
Re: Houghlines transform.- Generated HLS stream has leftover data warnings , that casue problem in RTL hanging
i am working on this project can we share our ideas .........however i am using xilinx system generator.....for this project.
i have send you my mail id as private message plz be free to mail me
Visitor juntawu
Hello, ka367,Have you solved the problem? I come across the same problem now. There are a series of warnings when i do the C Simulation. I cant figure out why.
Visitor ererge
Hey, is there any working code to plot the calculated hough2 lines into an hls image?
This is very urgent, got stuck now during my master thesis :(
Please contact me!
Visitor 920125lh
hi,I am studying hls and want implement canny using hls ,could you send me your code about this for reference.Thank you very much!
