Newbie mnazemi
How does Vivado schedule nested for loops?
Hi All,
I am thinking of moving from Intel FPGAs to Xilinx but haven't used Vivado since 2013. My knowledge about Vivado is limited and have a basic question about how nested for loops are mapped to hardeware.
Let's assume there is a function that gets called once in each iteration of a nested for loop. This function is the only thing that exists in the nested for loop and there is no additional operations performed.
I assume that Vivado allows you to implement the function once and use across cycles or implement the function multiple times and use it in parallel.
My question is if I decide to implement the function once and reuse it across cycles, does Vivado perform the scheduling automatically? If yes, is such scheduling done using logic blocks or a code that's generated for the coprocessor?
P.S. By scheduling, I mean reading proper data from memory, writing outputs to memory, deciding which iterations to perform first to reuse data, etc.
Thank you!
Re: How does Vivado schedule nested for loops?
  HLS by default keeps the loops rolled. So it builds the logic for 1 iteration and reuses across other iterations. Scheduling is taken care by the control stataemachine that HLS generates. So it is transparent to the user
Nithin
Scholar u4223374
In Vivado HLS, it's all done in logic blocks - the only thing the processor ever has to do is set up registers at the start and retrieve the results when the block has finished.
I'm pretty sure HLS won't do any re-ordering to optimize access; it does everything in the order you tell it to.
Nithin
Hi @mnazemi
If your question is answered or your issue is solved, please kindly mark the response which helped as solution (click on "Accept as solution" button below the reply).
Thanks and Regards,
Aoife
