lmaxeniro
How to get HW clock cycle by using HLS (C/C++ kernel)
we can capture or calculate the full clock cycle consumed by a specific task or a specific module in an RTL kernel design.
My question is, is there any API library for C/C++ that can be used, so I can do the similar thing in a C/C++ kernel (HLS way)?
Please give some hint/documentation / or example project if available.
Greate thanks!
lmaxeniro
@nithink
I know there are clk frequency will be reported in c-synthesis report.
What I means is: suppose I have a specific task algorithm block (for exp, a 1024 byte vector adder) and I want to know how many clock cycles will be consumed by this block, from the data input and the data output --can that be done? Will c-synthesis provide that kinds of report?
nithink
@lmaxeniro   when you run c-synthesis, HLS will report out the frequency that is achievable. You should get a rough estimate from that
Nithin
lmaxeniro
@nithink
nithink
@lmaxeniro   If the task is not inlined, HLS will report out the frequency for each of the subfunction.
So what you can do is, turn off inlining on the functions that you want to observe the period.
Below i have a simple example, where i have turned off inlining on sub functions, when you run through HLS, we can see the reports for these.
void sub1(int a, int b, int &c)
#pragma HLS inline off
 c = a + b;
void sub2(int a, int b, int &c)
 c = a - b;
void top(int a, int b, int a1,int b1, int &c)
int o1,o2;
sub1 (a,b,o1);
sub1 (a1,b1,o2);
sub2 (o1,o2,c);
