nanson
How to implement fully parallel adder tree for a for-loop accumulation
For the following accumulation loop, the target is to explore how to implement in fully parallel adder tree as the following figure shown.
Assume that the x[4] is completely partitioned and thus x[0]-x[3] is available at the same time.
I try either unroll the loop loop_acc or pipeline the function but still see the accumulation is executed in sequence.
Would you please help to point out how to achieve the goal ? Thank you.
---HLS code---
const unsigned int N_IN   = 4;
float add_tree(float x[N_IN]) {
   float acc_tmp=0;
   loop_acc:for(int j=0;j<N_IN;++j) {
      acc_tmp = acc_tmp + x[j];
   return acc_tmp;
nithink
@nanson you have floating point datatypes. HLS by default doesn't do expression balancing on these to avoid any functional mismatches with float types.
You can turn on unsafe_math_optimizations
config_compile  -unsafe_math_optimizations
partition the array fully and unroll the loop. That should work
Nithin
nanson
Hi, folks,
Does anyone have a comment/experience on how to implement a fully parallel adder tree for a for-loop accumulation?
Thank you very much.
nithink
Nithin
nanson
@nithink
Thank you for the information. It works but I have one question.
When I set loop trip count as 20 and then apply the commands you suggested, I got the following results.
In my expectation, the first layer should have 10 adders run in parallel, it seems to have 8 parallel adders as shown below. Do you know how to explain it?
akokha
Hi @nanson,
Vivado tries to minimize resource usage while achieving maximum performance. So, it reuses adders of level-1 in subsequent levels of adder tree whenever possible.
When performing 8 additions on 16 inputs (in0,..., in15) in level-1, 8 partial sums are generated and therefore, only four adders are needed to add pairs of these partial sums in level-2. So, we have four free unused adders in level-2 and six free adders in level-3, etc. As a result, vivado can schedule additions of four remaining inputs (in16 - in19) to be performed in level-2 and/or later levels using available unused adders.
You may take a look at the following figure for more clarification.
You can see that using maximum of 8 adders in each level (instead of 10 adders!) the best possible performance (unpipelined) is achieved.
Ali
