Observer xyzhou
How to use BRAM to read/write 8-bit array in Vivado block diagram?
Hi, everyone. I am quite new to HLS and Vivado.
I am working on making a function using HLS and then export the bitstream for my Pynq-Z1 board.
So my function has four input variables:
input1 is an array of ap_fixed<8,2>
layer10_out is an array of ap_fixed<8,2>
const_size_in_1, const_size_out_1   are two unsigned short number for settings.
void fecpred0(
input_t input1[N_INPUT_1_1*N_INPUT_2_1],
result_t layer10_out[N_LAYER_9],
unsigned short &const_size_in_1,
unsigned short &const_size_out_1
// self-defined interface
//#pragma HLS INTERFACE ap_ctrl_none port=return
#pragma HLS INTERFACE s_axilite port=return bundle=CRTL_BUS
#pragma HLS INTERFACE s_axilite port=const_size_in_1 bundle=CRTL_BUS
#pragma HLS INTERFACE s_axilite port=const_size_out_1 bundle=CRTL_BUS
#pragma HLS INTERFACE bram port=input1
#pragma HLS INTERFACE bram port=layer10_out
I am currenly using interface like above, after the synthesis in Vivado_HLS, I am confused how to create a block diagram for this.
Any suggestions? Thank you!
Re: How to use BRAM to read/write 8-bit array in Vivado block diagram?
Hi @xyzhou ,
Please check chapter9 of UG 871 on how to use the HLS generated IP in Vivado IP Integrator.
Hi @xyzhou ,
Observer xyzhou
thanks
I will take a more careful look at it
currently I actually use the axi-lite for data transfer, will change to axis for a trial
