Visitor muratozcn
How to use HLS_video haar cascade load data ?
Hi ,
Under HLS include video library, there is a header file for Haar cascade classifier library.
Inside the library, load haar_data function is given. I assume this is the classifier data for the object that we need to detect.
May I know how to use classifier data from OpenCV xml to this load haar data function? I got a hard time understanding the arguments in this function. Thanks.
He's been asked before. Unanswered.
https://forums.xilinx.com/t5/Vivado-High-Level-Synthesis-HLS/How-to-use-hls-video-haar-load-data/m-p/749712#M8244
https://forums.xilinx.com/t5/Vivado-High-Level-Synthesis-HLS/Does-hls-video-include-haar-Classifier/td-p/702847
回复: How to use HLS_video haar cascade load data ?
Hi @muratozcn ,
     HaarLoadData function has been defined in hls_video_haar.h.
     The hls vedio library has been merged into xfopencv since 2018.3. The previous lib is no longer supported by Xilinx.
如果提供的信息能解决您的问题,请标记为“接受为解决方案”。
如果您认为帖子有帮助,请点击“奖励”。谢谢!
